How do I connect a QuNeo to an iPad?
The QuNeo can be connected directly to an iPad via USB (using the iPad Camera Connection Kit) using two methods.
1. For connecting with a standard micro-USB cable, QuNeo should be placed into iPad mode (reduced LED brightness).
  • To put QuNeo into iPad mode, hold down the four central pads powering up the QuNeo (connecting the USB cable). The LEDs should swipe across the board in the usual manner, but with reduced LED brightness. The same action will take QuNeo out of iPad mode.
2. For full LED brightness you can use a powered USB hub as an intermediary between QuNeo and the iOS device.
