Can I use two SoftSteps at the same time?
Hosted mode is limited to a single SoftStep at a time, but a lot of SoftSteps can be used simultaneously if they're running in Standalone mode. The USB spec states "up to 127 devices, including hub devices if present, may be connected to a single host controller." As a class-compliant USB MIDI device, this applies to the SoftStep.
Please note that only a single SoftStep can be edited at a time using the editor.
