yes. The Advanced Editor allows for importing presets from the previous editor, 1.21. To import old presets to the new editor, do the following:
- Open up the Advanced Editor.
- If you want to import Hosted mode presets, skip this step. If you would like to import Standalone mode presets, switch over to Standalone mode by clicking the Hosted/Standalone switch.
- Go up to the File menu in the menu bar and select "Import Hosted/Standalone Presets from V1.21" (it will say either "Hosted" or "Standalone" depending on which mode you're currently in).
- When the file browser appears, navigate to and select the old SoftStep editor's "Presets" folder (not the contents of the folder, just the Presets folder itself), then click Choose/OK — the presets will be inserted at the end of the current preset list.
The Basic Editor does not provide this same functionality.
Presets created within SoftStep 2.0+ editors should remain backwards compatible — you can simply use the Export Preset and Import Preset options.
