QuNexus vs K-Board - Feature Comparison
Both devices have the same form factor, and are unbreakable and untraportable by design.
Both devices are USB powered, and work out of the box with any music software on a computer or tablet.
Both devices contain touch sensitive Smart Fabric sensors under every key, to allow expression when you play.
K-Board is optimized to have killer features but cost under $100.
QuNexus includes more connectivity for people with a lot of gear. That includes DIN MIDI* and CV connectivity (for hardware synthesizers), and some advanced features related to the QuNexus Controller Layer.
See the charts below for a more detailed comparison between K-Board and QuNexus:
Controllers
K-Board | QuNexus | |
25 velocity‐sensitive, LED backlit keys | X | X |
Pressure-sensitive keys | X | X |
Tilt-sensitive keys | X | X |
Pitch bend pad | X | X |
Octave up/down buttons | X | X |
Velocity on/off button | X | X |
Pressure on/off button | X | X |
Tilt on/off button | X | X |
Toggle on/off button | X | X |
Sustain button | X | |
Preset button | X |
Connections
Micro-USB | X | X |
Mini-USB Expander Port | X | |
3.5mm CV Input / Expression Pedal Input | X (1 stereo input) | |
3.5mm CV Output | X (2 stereo outputs) |
Power
USB bus power | X | X |
External power | X (USB power supply) |
Velocity Curves
Linear | X | X |
Logarithmic | X | X |
Sine | X | X |
Cosine | X | X |
Exponential | X | X |
Inverted | X | X |
User Tables | X (2 user tables) |
Data Transmitted
MIDI over USB | X | X |
MIDI over 5-pin MIDI cable | X (w/ MIDI Expander) | |
Control Voltage over 3.5mm TRS cable | X |
Misc
Number of onboard presets | 1 | 4 |
Octave shift range | "-2 to +3 octaves" | "-2 to +3 octaves" |
Global key pressure | X | X |
Global key tilt | X | X |
Separate pressure data per key | X | |
Separate tilt data per key | X | |
Channel-Per-Note (Channel Rotation) | X |
