Can I use two K-Boards at the same time?
Yes. A lot of K-Boards can be used simultaneously. The USB spec states "up to 127 devices, including hub devices if present, may be connected to a single host controller". As a class-compliant USB MIDI device, this applies to the K-Board.
Please note that only a single K-Board can be edited at a time using the editor.
