Connect QuNexus to MIDI hardware:
The image shows QuNexus connected to a hardware MIDI device via our MIDI Expander (sold separately):
- Use a USB A-to-Mini cable to connect the QuNexus Mini port (on the right side of the QuNexus) to the USB “Expand” port on the MIDI Expander.
- Connect the power supply to the MIDI Expander USB “Power” port.
- Connect the MIDI Out on the Expander to the MIDI In on a synth or other MIDI device.
All Factory Presets are set up to send MIDI out through the MIDI Expander so once everything is connected you should be able to play your MIDI Device.
