How do I find out what firmware is installed on my 12 Step?
Finding out what firmware version is installed on the 12 Step is simple. When a 12 Step is powered up it will briefly display the firmware version that is currently installed on it. Just plug in the 12 Step and look at the first thing displayed (typically something like A1 or A2) — that's the firmware version. This information is also available via the 12 Step editor.
To find out what firmware version is included in the editor, do the following:
  1. Open the editor you're curious about.
  2. Mac Users: Go up to the "12 Step Editor" option in the menu bar and select "About 12 Step Editor". Windows Users: go up to the Help menu in the menu bar and select "About 12 Step Editor". The main window will now display information about the editor and connected 12 Step (if one is connected).
Expected FW lists the firmware version included in with the editor — this is what will be installed if a firmware update is initiated.
Found FW lists the firmware version currently installed on the connected 12 Step.
Editor Version lists the version number of the editor itself (not firmware related).
