Can I use two 12 Steps at the same time?
Yes. A lot of 12 Steps can be used simultaneously (if you have the available USB ports and power). The USB spec states "up to 127 devices, including hub devices if present, may be connected to a single host controller". As a class-compliant USB MIDI device, this applies to the 12 Step.
Please note that only a single 12 Step can be edited at a time using the editor software.
2 out of 2 found this helpful
