Why does the input sound doubled when using the K-Mix as an interface?
The K-Mix also functions as a traditional mixer when used as an Audio Interface, passing incoming audio to the outputs through the inputs as well as passing it to a connected computer. If you want to do all your mixing in your DAW, make sure that your channel inputs are down if you have the USB routing set to PRE for the inputs.
