Can I rip presets from a 12 Step into the editor?
No, the 12 Step does not support ripping presets from the board onto a computer. This is why it is very important to always back up your presets if you do not want to lose them — they cannot be retrieved from the 12 Step itself.
If you want to rip presets in order to transfer them over to another computer, you should instead use the Export Preset option in the File menu of the 12 Step Editor — then import them on the other computer using the Import Preset option (also in the File menu).
