Can I rip presets from a SoftStep into the editor?
No, the SoftStep does not support ripping presets from the board onto a computer. This is why it is very important to always back up your presets if you do not want to lose them — they cannot be retrieved from the SoftStep itself.
If you want to rip presets in order to transfer them over to another computer, you should instead use the Export Preset option in the File menu of either the Basic Editor or Advanced Editor. Then import the resulting preset files on the other computer using the Import Preset option (also in the File menu).
